Lift the rear or drop the front??? Need option???
Old Apr 25, 2011 | 10:58 PM
tyes's Avatar
Just sas'ed it and with 5inch lift from TG.. It looks high in the front about 2-3 inches higher from rear. I was told to get NON HD leafs so it would sag to 4 inch, but it pretty off.. Should i use smaller shackles up front and longer shackles in the rear? Rear has a pro comp 4 inch lift with downey shackles, it seem to be the same size as the TGs.. Dont really feel like i should mess with rear as it may effect drive line also. Really wanted to keep it cost effective..lmk your ideas....
Old Apr 26, 2011 | 05:21 AM
rattlewagon's Avatar
The front will settle when the leaves break in. If your too impatient, take a leaf out.
Old Apr 26, 2011 | 05:32 AM
waskillywabbit's Avatar
The problem is the rear lift is new and hasn't settled. The rear is PC and probably has or was shorter than advertised.
Patience or swap rear lift.
:wabbit2:
Old Apr 26, 2011 | 12:29 PM
tyes's Avatar
rear lift has been on the car for many many months... so its settle for some time now.. was really hoping the TG would settle so i dont have to spend more $ than i already have. i was told about adding a 8" shackles or add a block.. really hate the idea of a blocks... Shackles i can see why, but at 8", is that safe..
anthony1's Avatar
Wow, you're in Fresno. Did you go see Marlin?
Old Apr 26, 2011 | 01:17 PM
tyes's Avatar
I've stop by a few times but not for this question...
Old Apr 26, 2011 | 01:23 PM
sebastianholmes's Avatar
take some leaves out of the front
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
