leveling kit for a 90 pickup
Old Oct 1, 2012 | 06:58 PM
my90yota4x4's Avatar
http://item.mobileweb.ebay.com/viewitem?itemId=251001309350&index=15&nav=SEARCH&n id=13542734695
Does anyone know if this works and where exactly do they go since theres no coilsprings??
I just wanna level out my trunk for now till I have enough money for a lift haha
Old Oct 1, 2012 | 07:02 PM
NickMiller's Avatar
These are called Ball Joint spacers (TONS of info on this) and they are designed to go in between the control arm and upper ball joint on your front suspension. This will just lift your front 2 inches, not the whole truck. If you want a small lift you could go with these & a set of 2 inch lift Old Man Emu leaf springs in the rear and that will level the truck & give you room for 33 inch tires!
Remember that you have to get longer shocks with this setup though...
Old Oct 1, 2012 | 07:13 PM
Ohhh makes sense haha cool man but nah I just want to lift the front right now because ifs nose dipped and I have a brand new set of pro comp mud terrains 31's but I am planning on going on 33's later
Old Oct 1, 2012 | 08:00 PM
NickMiller's Avatar
You can find BJ spacers smaller than 2 inches if it's too much for what you need... Any pics of the truck?
Old Oct 1, 2012 | 08:36 PM
Luvmeye22re's Avatar
Those ball joint spacers on ebay Kind of sketch me out. For one thing SDORI and Roger Brown strongly back the 1.5" spacers from what I have seen as a larger one really get's you into the iffy range with your cv axles. For 2 I was also looking on ebay for a small lift for my 94 4Runner. Their kits ALL state that the lift is for a 2" front and 1.5" coil spacer in the rear which is exactly the opposite of what any 2nd gen 4runner needs. Even if it's a marketing booboo it tells you that the company doesn't care enough to know what the vehicle needs, or they don't care enough to even label it correctly if in fact it is a 1.5" front and 2" rear lift. I also would question the type of material they use and whether or not they use properly graded hardware. If you notice the descriptions are kind of weak and I'm sure the return policy isn't very strong either. I'm sure people have bought them and they were fine but your only saving 20-40 dollars over our vendors who carry the tried and true.
It's up to you ultimately, I'm not trying to be your dad. I'm just saying what route I'd go.
Either way, it's sketchball.
I'd get your bj spacers from 4crawler, SDORI, or Wabfab. They are on hundreds of vehicles on this site with little to no problems with their spacers and wabfab even offers a coupon code for their parts just for being a Yotatech member. The little money you save on ebay could cost you a LOT of headaches. If you have a problem with any of the companies I suggested they will take care of you quickly, efficiently and properly. These companies also put their effort towards keeping this very site alive so they deserve the business.
Old Oct 1, 2012 | 08:39 PM
@NickMiller
I want two inches because I want to go for the pr erunner look.. yeah I'll put some up tomorrow because I can't figure it out on my phone so I'll have to do it through my computer haha
Old Oct 1, 2012 | 08:45 PM
@Luvmeye22re
Yeah I have doubts about it I don't really trust eBay much Ima look into those companies you mentioned
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
jerusry
Oct 19, 2015 05:28 PM
crashburnoveride
Aug 28, 2015 09:20 PM
raiderhawks00
Jul 8, 2015 06:23 PM
