Leaking coolant
Old Jan 10, 2014 | 03:23 PM
yota_94's Avatar
Leaking coolant
Hey it's been a while since I've posted anything. So I have a problem with my 94 Toyota pickup 22re leaking coolant. I have replaced the radiator, check the hoses, & also there is no evidence for leaks excepts the the back end of the motor on the transmission where it looks wet. Any help would be greatful because I have ran out of ideas what it could be.
Old Jan 10, 2014 | 03:47 PM
Black_1985_SR5's Avatar
if there are no hoses or anything that can leak back there then your head gasket may have failed... do a leak test and find there source if you dont know what the cause is dont throw random money at it
Old Jan 10, 2014 | 04:36 PM
93 Toyota 4x4's Avatar
there's a heater hose back there, along with a head plate, which will be a royal pain to remove and replace the gasket..pray it's the hose...
Old Jan 10, 2014 | 04:41 PM
thefishguy77's Avatar
X2 get it good and dry back there and get a small mirror. Like a makeup mirror or dentist mirror. Then you should be able to shine a flashlight back there and see if its dripping with a leak down test.
Blamalam
Mar 12, 2022 07:34 AM
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
