Leak in bell-housing
I'm in the process of swapping the motor in my truck. After it was removed I noticed some fresh oil in the bell-housing, any idea as to where it could be coming from? Easy fix?
Thanks (:
Thanks (:
This.
These are the only two seals that would allow oil to flow directly in to the bellhousing.
Since you have the engine out, yes its an easy fix. Replace both seals. The input seal will require you to remove the input shaft collar.
he's gone
7
Dec 3, 2019 07:08 AM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
