Leaf spring bolt sizes?
Old Dec 8, 2014 | 08:11 PM
mountainbrew's Avatar
I am replacing the leaf spring bushings on my 86 4Runner. I bought the energy suspension poly bushings for stock leafs. I want to make sure I have the right size bolts to put in after I cut the old seized ones out. My searches came up with several different sizes. Anyone know for sure?
Old Dec 8, 2014 | 09:24 PM
wyoming9's Avatar
Red face
For bolts like that I just buy them from the dealer
Old Dec 9, 2014 | 05:17 AM
Is it going to be a ton more expensive than anywhere else?
Old Dec 9, 2014 | 08:43 AM
highonpottery's Avatar
i believe the stock diameter is 18mm. sometimes you'll find a smaller bolt with a sleeve. you can get them anywhere they sell large metric hardware - like ACE or Grainger for example. try to get grade 8 or 10 for strength. you can also order them online individually or as a shackle kit from a plethora of retailers. concerned with dealer prices - call them and ask.
also, if you got new bushings, make sure they're 18mm bore not 3/4"(19mm-ish) or you will likely have to up size to 3/4" and drill the bushing
Old Dec 9, 2014 | 12:23 PM
wyoming9's Avatar
Red face
Toyota for the special hardware I have found to be really reasonable .
I just hate when I work on a Toyota with all different cobbled hardware
If I look maybe I can find the new bolts I have and measure.
88sasturbotoy
Jan 30, 2026 01:57 PM
shisha1999
Sep 21, 2015 08:22 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Nickdigg
Jul 7, 2015 06:04 AM
