Just bought a 95 4Runner 22-RE, some questions
Old Dec 1, 2010 | 09:08 AM
Belize Off Road Team's Avatar
Exclamation Just bought a 95 4Runner 22-RE, some questions
AS many of you remember me, i also own a 91 4Runner V6.
Well i now bought a 95 4Runner base package with the 4 cyl.
and here are a few issues right now that i need help with...
when i have the head lights on and heater on it bogs down and surges under acceleration and when i put the signals on it can nearly stall it when the other stuff is on. now i know it needs some work but where should i start??
Old Dec 1, 2010 | 09:49 AM
Anyone?
Old Dec 1, 2010 | 10:00 AM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old Dec 1, 2010 | 10:11 AM
okie81's Avatar
I had a similar problem on my 95, it was a bad ground
Old Dec 1, 2010 | 10:21 AM
dynamic73's Avatar
I would check all the body grounds in the engine bay. Sound like one maybe off or corroded.
Old Dec 1, 2010 | 07:31 PM
Awesome ill go see what i can see. Thanks. Look forward to MANY more questions to come! lol
Old Dec 1, 2010 | 07:35 PM
Moonfish's Avatar
Originally Posted by dynamic73
I would replace all the wires from the battery in the engine bay. We all know they are undersized and poor and old.
Fixt
You welcome
Old Dec 4, 2010 | 09:15 PM
engine issues on my 95
okay number 1, i looked at my engine and well the sticker on it says 22R...but I'm pretty sure it's a 22R-E. cause it has EFI.
number 2, i think my crank shaft seal is gone. so like on average whats the most it would cost to get it repaired?
Old Dec 4, 2010 | 09:34 PM
nobody?
Old Dec 5, 2010 | 11:12 AM
nobody has a rough estimate on cost to get a crankshaft seal replaced? id do it if i had tools but i dont at the moment.
Old Dec 5, 2010 | 11:39 AM
camo31_10.50's Avatar
probably around $200 i'm guessing...
i do all of my own work, so to me it costs roughly $5 for the seal from Oreilley's.
Old Dec 5, 2010 | 11:43 AM
sam333's Avatar
It depends on which seal. There are two crank seals ( one in front , in the timing cover and one in the rear under the flywheel. If its the one in the rear you have to pull the engine or trans, then the clutch and flywheel( very expensive if a shop does it in the US) to get at it. The one in the timing cover is much easier ( cheaper). I dont what a shop would charge in your area ( I dont even know what country you are in).
Old Dec 5, 2010 | 12:22 PM
im in edmonton. and its the one in the front, cause the front of the engine is soaked in oil and anything under the engine is just black from caked on oil.
Old Dec 5, 2010 | 12:25 PM
richf's Avatar
figure 60-90 bucks a hour and maybe 2-4 hours labor.
Old Dec 5, 2010 | 12:50 PM
okay that's not that bad. okay so one question then, what tools would i need to change this crankshaft seal in the front of a 22re?? and maybe a part number of the seal i would need. cause i might be able to borrow some tools.
Old Dec 5, 2010 | 01:01 PM
richf's Avatar
You will need a socket to take the crank bolt off and you will need little wrenches for the bolts holding the oil pump on. It might just be the oil pump gasket that is bad. You will also have to replace that gasket and might as well replace the oil pump also if you have it off.
Old Dec 5, 2010 | 07:31 PM
okay so, does anyone know the sizes that i would need exactly for the tools. and i cant afford a new or used oil pump so for now just seals i will be replacing. So if anyone knows the size of tools that i would need and the part numbers for the oil pump seal and front crank shaft seal i would more then greatly appreciate it.
Old Dec 6, 2010 | 07:56 PM
anybody know what size tools are needed? cause if not tomorrow when i get paid im gonna take my truck in and get the work done for $240
Old Dec 6, 2010 | 11:57 PM
sam333's Avatar
Get a manual.
Old Dec 28, 2010 | 12:34 PM
Exclamation 22RE front main seal help
OKAY well last time i posted up i got a few replies. So Here is what i have figured out so far:
Loosen belts
remove crank pulley
remove/replace oil pump o-ring
remove/replace sleeve w/ speedi sleeve?
replace front main seal and reassemble?
So is there ANYTHING else i need to know at all?
BTW its my 95 4Runner 22RE.
And for tools i need:
Strong arm (torque wrench)
sockets
As far as i know that's it. Anything else that is Necessary?
