journey of a broken stud
Old Mar 20, 2021 | 07:51 AM
jdfnnl's Avatar
It started with the simple replacement of the front exhaust pipe after breaking, yet one of the studs wasn't going to let it be so easy.
My approach started with cutting a slit in the bolt and a slotted screw drive on the end of a socket, but I quickly gave that up in favor of boring a 1/4" hole into the bolt for a reverse-thread extractor. Despite the extractor getting a nice grip and several days of dousing the area with pb blaster from both sides, the stud was still not going to budge. Rather than grabbing a longer wrench and risk breaking the extractor in the bolt, I opted for brute drilling and chiseling.
The pic shows a 5/16" bore in an m10 bolt, about the largest possible without getting into the threads. In lieu of a die grinder, I do have a dremel .. maybe grind away at what remains with a carbide bit on low speed? Then maybe work at cutting what remains with an m10-1.25 tap? It is thin enough at this point that I would also consider going at it with a screwdriver or cold chisel and a hammer, but something long lest my hands be in the way. Any points of advice people have for putting this one in the bag?
Old Mar 22, 2021 | 11:00 AM
rattlewagon's Avatar
Heat and a easy out maybe? There isnt that much left of that bolt in there.
Old Mar 22, 2021 | 11:38 AM
87-4runner's Avatar
Just drill it out and tap it to the next bigger size...
Old Mar 22, 2021 | 05:44 PM
Blueman's Avatar
Yes, tap it to a larger size. Or if you're picky, helicoil it.
Old Mar 23, 2021 | 09:57 AM
jdfnnl's Avatar
Finally got this one -- tried using the extrator again but it wasn't catching so I went at the thin side of what was left of the stud with the dremel then peeled back the threads with a flat screw driver until I could twist the rest out the back .. after all that without much visibility, threading a bolt through now, it seems to hold surprisingly well.
Old Mar 23, 2021 | 10:33 AM
87-4runner's Avatar
plowzilla
Aug 12, 2013 09:14 PM
Rusker
20
Aug 6, 2010 04:51 AM
GenXr
Jul 8, 2008 07:32 PM
hirsche23
Apr 17, 2006 04:41 AM
