intake difference...
Old Jul 27, 2008 | 09:12 AM
stupid_mud_gremlins's Avatar
I've got a buddy that's doing a 22re swap, what is the 4th intake vacuum line, I know the motor he is putting in was from an automatic, and his is a standard. I'm guessing that the fourth on the donor is for the auto tranny... Am I right in assuming that swapping the intakes is the easiest fix for this?
Old Jul 27, 2008 | 09:26 AM
abecedarian's Avatar
is it possible to get pics?
DeathCougar's Avatar
The intakes between matching body styles of trucks is the exact same.
The throttle body can be different. Just follow the vacuum diagram under the hood on the sticker. Anything left over can be capped.
Old Jul 27, 2008 | 10:33 AM
I'll try and get pics if I'm over there tonight. And as always, thanks to DC for the advice as well. I kinda thought it would be something like that from his description...I figured the whole intake might not be a bad idea as he has AC as well...
Old Jul 27, 2008 | 10:41 AM
the intake shouldn't make a huge difference, if you change things over from the old manifold to the new. the a/c idle up switch is on the valve cover so that has to get moved over too.
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
mreagen
Oct 5, 2015 04:27 PM
bradahman
Oct 1, 2015 09:24 AM
