inclometer
Old Oct 6, 2007 | 06:21 PM
tampabayota's Avatar
inclometer
i just picked up one and i started the install tonight but im confused on what wire is the pos+ and what one is the ground. there is a solid black and a black/white
Old Oct 6, 2007 | 06:25 PM
OSU4Runner's Avatar
Just touch each of them to each terminal on your battery carefully. If it doesn't light up swap the posts. Problem solved....
Old Oct 6, 2007 | 06:39 PM
that will work? it wount screw it up?
Old Oct 6, 2007 | 06:41 PM
DeathCougar's Avatar
if i am correct, you could touch the leads to either terminal and the light will turn on.
Just be sure the "light off" button is not clicked. I almost tore my dash apart when I installed mine becuase I didn't check that button first.
Old Oct 6, 2007 | 06:45 PM
btw Toyota does make a harness that is plug and play for the inclinometer lighting. Goes between the wiring.
*edit* Found a pic:
They are only $15 or so, but very hard to find. According to my Local Toyota dealer, I got the last new one in the US. That may or may not be true, so check with your local dealer.
Old Oct 6, 2007 | 06:47 PM
mines already torn apart lol i am replacing my dash too cuz its all cracked, so i found a good dash and found an inclometer too. it should look good in the truck.
Old Oct 6, 2007 | 06:49 PM
no thanks on the plug im just going to splice in to dash light circut.
modernbeat
Feb 28, 2013 05:16 PM
sleaz22xx
Sep 19, 2008 10:15 AM
vmax84
Sep 1, 2006 01:13 PM
AznSky
Jun 20, 2003 10:52 PM
