im lost..!!!!!
Old Apr 18, 2012 | 11:41 AM
my94toyinpa's Avatar
im lost..!!!!!
94 toy 4x4 ifs front end. is pulling to the left. i have changed . pitman arm,idler arm, tie rod ends,steering stablizer,brake calipers.brake hose's. only thing i havent changedor looked at is wheel bearings, and steering box..it does sway on the road and have a shimmy at 90 mph..think the tires r no good .yes the shocks r getting replaced when i put the lift on it.so what else can i look for ?????? mabe oh yea... yes its lined up to..its just a pull or drift ???the tires r not getting worn out..could something be bent that im not seeing ..this is the only thing wrong with truck...please anything u suggest i will try...thank u...
Old Apr 18, 2012 | 11:57 AM
DeathCougar's Avatar
Take it to an alignment shop (not Les Freakin Schwab) or to a frame shop. See if the frame is bent
Old Apr 18, 2012 | 12:51 PM
nothingbetter's Avatar
If you've changed all that stuff, had it alligned (by a good shop) and still pulling left. Its most likely in your rear end. either the pass rear tire is back or the drivers rear tire is forward. Or a mixture of both.
Old Apr 18, 2012 | 01:06 PM
wii_tarded's Avatar
Tire pressure? if one side is low you will pull that way. Brakes; caliper sticking on one side would cause it to pull. These you can check for free...
Old Apr 18, 2012 | 02:15 PM
WHEELER8688's Avatar
when any vehicle is pulling to either side the FIRST thing to check is the tires. I have seen different cars pull to the side by just having a tire problem
vanduzerwilliam
Sep 21, 2015 04:29 AM
jmw2010
May 28, 2014 01:57 PM
vamped400
Jun 17, 2013 04:33 PM
edge2009
Mar 15, 2013 01:28 AM
Lunnzz
Oct 25, 2009 02:10 PM
