IFS Third Member Swap Questions
I finally got it the new one back in today. Went pretty smooth.
How much oil does the front diff hold? I put a little over 1.5 quarts before it started spilling out.
Thanks for all of the help.
#28
I wonder if the ones using the 1/2" bolts are drilling out the splines in the stub shafts. I bet with out the splines the 1/2" would fit through both sides? In the process of doing this, debating on if I want to switch the bolts out. I just got to get off my butt and start fitting bolts. lol.
#31
#34
FYI, 7/16"(11.1125mm) is much closer to the size of the studs(12mm) than 3/8"(9.525mm). But 1/2"(12.7mm)is even closer.
#36
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
