IFS axle tube torx bolts.....
Old Feb 13, 2008 | 05:19 PM
4WDarren's Avatar
Going to do the side gear shaft seal this weekend, as I've got a nice leak coming out of the driver side axle tube
Looking at the instructions( http://personal.utulsa.edu/~nathan-b...le/22repla.pdf ), in order to remove the side gear shaft/tube assy., I need to take out 4 torx bolts. Anyone happen to know what size the socket would be, or where to get one (my guess is probably Snap-On or something?). It'd be nice to have the stuff I need before ripping everything apart.
Thanks!
Old Feb 13, 2008 | 05:55 PM
AxleIke's Avatar
Hmm.
Must be an ADD thing.
I'd be interested to see where this is needed.
BTW, that link doesn't go anywhere.
Old Feb 13, 2008 | 06:38 PM
4WDarren's Avatar
Fixed the link.
Old Feb 13, 2008 | 06:41 PM
AxleIke's Avatar
Hm. Sorry, non ADD have regular bolts. Not torx. Good luck.
Old Feb 13, 2008 | 06:46 PM
1993toy's Avatar
The socket is an E14 torx. I am in the process of swapping diffs and got the socket set at Harbor Freight for $6.00.
Old Feb 13, 2008 | 07:14 PM
881stGenRunner's Avatar
there is a regular 12 pt metric socket that will fit over it tight enough to not need a Torx socket. Although for $6.00 i would go for it.
Old Feb 14, 2008 | 07:03 AM
eric-the-red's Avatar
Thanks!
If you're in my area I have a socket that fits, and I think also a spare seal that I never used on my 93. No charge for the seal if you want it.
Old Feb 16, 2008 | 08:14 PM
4WDarren's Avatar
Thanks for the replies! Got the Mac guy to swing by my work today and picked up a socket. Only $6.50!
Old Feb 17, 2008 | 07:41 AM
leebee's Avatar
there is a bearing inside that axle shaft that you will have to press off if it needs replacing. might as well service the wheel bearings etc while you are at it, everything needs to come apart anyway.
lee
Old Feb 17, 2008 | 11:28 AM
Jay351's Avatar
Its easier to do if you have the torx socket, then its 4 bolts (two short and then two long arse bolts) then she slides right off. You do need to unbolt the ADD actuator if im not mistaken. I just finished swapping diffs and I had to tear down both of my diffs to swap parts. Make sure to put a little form in place gasket to make sure you don't get anymore leaks, even though there is an internal o-ring to prevent that.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
delmert
Sep 30, 2015 04:34 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
dfarr67
Jul 30, 2015 07:08 AM
