Idle "lopes" ONLY at around 2100 RPM
Old Jul 24, 2012 | 06:24 PM
Ocell's Avatar
I replaced most of my vacuum lines with silicone lines tonight. Unfortunately, the surging problem is still there. It DOES surge harder and faster now, so at least my work made the engine more responsive.
Dale, I'm hoping you can tell us which line was disconnected and plugged, and maybe we'll get this sorted out.
Old Jul 25, 2012 | 07:10 AM
Ocell's Avatar
This morning I unplugged my Throttle Position Sensor and the engine runs fine. At least now I have a shot at actually getting an emissions test.
Can anyone think of downsides to running without the TPS hooked up, long term?
[Update]
Doing more research today, I'll check to see if mine is still good but just out of adjustment. If it's bad, I'll put a new one in. Driving without the TPS connected doesn't look like a viable long-term solution.
Old Jul 25, 2012 | 05:28 PM
Dale Johnston's Avatar
From: Strafford Missouri, right outside of Springfield
yes i can post pics but not for a day or so. it looks like it might be the TPS from i understand, it is probobly bad. and if it is unhooked that might explain the drastic change from cold to hot idle speed. ill try to post pics tomorow or the day after.
Old Jul 25, 2012 | 07:34 PM
Ocell's Avatar
I ran through the TPS calibration procedure tonight and it has fixed the problem for me. I'm very very happy.
Dale, there aren't any vacuum lines running to the TPS itself, just an electrical harness, so I'm still curious about what was plugged up and disconnected that could also clear this up. Adjusting the TPS is going to help ashamsuddin since he's carb and not EFI.
Old Jul 26, 2012 | 06:05 PM
  #25
here is the thing that was unhooked, it is not a very good pic but i cant get my camera to work so i used my phone, hope some can identify it and maybe it will help some of us. i tried to figure out what it was using my toyota manual on disc but that wasnt very helpful...
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
accuracy
Aug 4, 2015 08:05 PM
JefferDean
Jul 31, 2015 10:39 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
