Idle bounces....
Old Aug 15, 2008 | 05:39 PM
The Stig's Avatar
Idle bounces....
Hey guys,
I'm not very good with engines, so i'll need some help with this one.
When i cold start my engine (3.0 V6 3VZE), the engine idle is fine, no problem here, but once i get the engine warmed up and and let it idle, the idle begins to bounce up and down. The idle bounce is not much but i'm pretty sure there's something wrong. Any ideas of what's wrong?
Old Aug 15, 2008 | 05:43 PM
abecedarian's Avatar
Check the throttle position sensor adjusment. If the ECU is not being told the throttle is closed, it will use the O2 sensor to adjust the fuel mixture and the idle speed will 'hunt' or fluctuate.
Old Aug 15, 2008 | 06:08 PM
The Stig's Avatar
I also noticed that when i do start up the truck, it's kind of rough, would adjusting this (if this is the case) allow for a smoother startup?
Old Aug 15, 2008 | 06:16 PM
idle speed and timing are set with the engine warm, not cold
Old Aug 16, 2008 | 03:37 AM
Flash319's Avatar
Your idle is to high. This could be from air in the coolent, vacuum leak or just out of adjustment.
Old Aug 16, 2008 | 03:43 AM
jimbos_4runner's Avatar
also could be fuel filter!
Old Aug 17, 2008 | 01:16 PM
The Stig's Avatar
thanks guys, earlier the weather wasn't cooperating with me, so hopefully soon i will be able to diagnose the problem.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
