idle air control valve o ring?
hello
i have a 1990 22re 2 wheel drive with a stick shift.
i was told by toyota parts that the idle air control valve does not have a o-ring.......
and i was told by toyota parts that the automatic transmisson.. does have a o-ring ...
i find it hard to beleave that the stick shift does not and the automatic transmisson does please let me know ..
thanks
thanks
wait I'm confused
what are we talking about here now, a transmission or an IACV?
I don't think there's an o-ring in it regardless; matter of fact, I think they would be the same IACV no matter the trans
but on an auto trans, the idle is just set higher when in a nuetral gear
if there IS an o-ring in it, I don't think it's servicable
but, I could be proven wrong...
I'm pretty sure that shafner30 is talking about the o-ring gasket for the AAV (auxiliary air valve), what you guys are calling the IACV, shown on page EG1-202 of the fsm:
http://personal.utulsa.edu/~nathan-b...34throttle.pdf
It's not unusual for there to be differences in the engine based on things like transmission - the throttle opener, for instance. Also, I think 2WD 22RE trucks lack a knock sensor while 4WD trucks have them.
But I agree, shafner30, that it is unlikely that the AAV on the MT trucks lacks a gasket. I have the 3VZE so can't tell you for sure. Maybe SOMEONE here will let you know...
Are you refering to this "O" ring??
If so I don't believe getting one in a rebuild kit will happen.
Buying one from yota is probably the way to go.
Good luck, I found the IACV to be a real pain.
Repo
Repo
yes i am talking about the o ring on the idle control valve..the one in the pic above this post.
toyota parts say..
if you have a automatic transmission you need the o-ring...
if you have a manual transmission you dont need it...
i find it hard to beleave that..
let me know
toyota parts say..
let me know
It has a removable cover that exposes what looks like to be a plundger with ring that could possibly be backed out but I'm waiting to find some more info before I go and screw with stuff I know nothing about.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
