ICM Test?
Old Apr 17, 2018 | 06:17 AM
High Alt Gold Miner's Avatar
ICM Test?
1988 Pickup, 3.0L
Is there any way to test this Ignition Control Module? It's a fairly expensive part for this model and I don't want to replace it unless I'm sure it's bad. Any help much appreciated.
Old Apr 18, 2018 | 06:31 PM
Kolton5543's Avatar
Most part stores can test many different modules. I'm not sure if Toyota modules can be tested at the part stores. They are a rare part to fail. Got any buddies with a 3.0 truck you can plug yours into to check?
Old Apr 18, 2018 | 10:01 PM
Co_94_PU's Avatar
Full specs were never published.
The fact you are asking says you probably don't have the tools required for a "proper analysis" even if there were good factory specs given.
Scope did a pretty in-depth write up on these at some point but I don't remember the thread title. If you want to Google for it you may or may not find it interesting..
For a layman's test, if you have healthy sparks it's probably fine. If you want some diy bench tests you can find some on YouTube..
Make sure the mounts/ground are clean and tight and the wires are intact.
mason1982
Jul 30, 2017 06:17 PM
Waterfreek
Jul 23, 2017 07:59 PM
irbigbird
May 8, 2014 06:44 AM
