i need help!!!!!!!!
Old Jul 9, 2008 | 02:53 PM
galloway's Avatar
no i got them put them on lined them up and ya put them in and now this
Old Jul 9, 2008 | 02:56 PM
Cyberman's Avatar
The bearings are standard, and the right ones for the 3VZE. What about the rings Brand and part#
Old Jul 9, 2008 | 02:58 PM
abecedarian's Avatar
peek in and see if the ring ends are touching each other. and the end gaps should not be all lined up. they should rotate, either clockwise or anti-clockwise, about 120 degrees apart from one ring to the next
Old Jul 9, 2008 | 03:00 PM
76ANTHONY's Avatar
THIS IS VERY IMPORTANT. measure gap.....
Old Jul 9, 2008 | 03:01 PM
  #25
if they're all lined up, the oil has a straight path through the rings... and your compression does too.
Old Jul 9, 2008 | 03:02 PM
  #26
2muddytoys's Avatar
i have put together many of these motors and it sounds like the rings are over sized or piston or baering/rod caps are on wrong
Old Jul 9, 2008 | 03:05 PM
  #27
galloway's Avatar
ya i put them off set i was saying i got them all to the way the book said. sry about the mix up. but i cant find the box the new rings came in so i cant tell you the name but im checking the ring gap right now
Old Jul 9, 2008 | 03:20 PM
  #28
and if you've just installed the pistons, rings and bearings on the crank, rotating the crank by hand is gonna be a beatch cause it's all not broken in yet.
Old Jul 9, 2008 | 03:28 PM
  #29
galloway's Avatar
ya, this is my first rebuild and im fliping out cause i dont want any thing to go wrong with it. and every thing look ok as far as the rings and bearings. thanks guys and i will start to look off that sticky
Old Jul 9, 2008 | 03:31 PM
  #30
76ANTHONY's Avatar
hey, it built up my arms
Old Jul 9, 2008 | 03:33 PM
  #31
TOYOTA 1's Avatar
did you get the rod caps mixed up by accident??
i would install #1 piston, then turn the crank, install #2, then turn the crank..etc. that way you can find out where the problem is!
Old Jul 9, 2008 | 03:35 PM
  #32
"For a limited time only... 76ANTHONY's precision guided workout for building biceps, triceps, delts... and 22RE engines."
Old Jul 9, 2008 | 03:44 PM
  #33
76ANTHONY's Avatar
WOOOHOO, im gonna be rich
Old Jul 9, 2008 | 03:46 PM
  #34
galloway's Avatar
and if you call now we will give you some free badger milk.
and im working from right 1 to left than back to right
Old Jul 9, 2008 | 03:54 PM
  #35
76ANTHONY's Avatar
BADGER MILK, LMAO....
Old Jul 9, 2008 | 04:46 PM
  #36
hmmm...
I hear badgers like it that way.
Old Jul 9, 2008 | 04:49 PM
  #37
galloway's Avatar
dude no way me to
