I have clutch pressure, but wont switch gears!
Old Feb 2, 2013 | 02:29 PM
1986YotaBeast's Avatar
Thumbs up I have clutch pressure, but wont switch gears!
Hello, So I ran into a big problem, Im guessing someone stole my bellhousing bolts because, a few days ago my tranny disconnected from my engine! I know, pretty bad. And today I got some new bolts, and got it connected, I then bleed the clutch, it has pressure, but wont switch gears What could be wrong? and suggestions would be great!
Old Feb 2, 2013 | 02:45 PM
waskillywabbit's Avatar
Maybe they stole your clutch too!
Is your clutch pedal bracket busted?
:wabbit2:
Old Feb 2, 2013 | 02:49 PM
They didn't steal my clutch, I had it parked at school overnight, bad idea, I then wen't to take it home during lunch, and it disconnected while i was driving, so my clutch is still there.
Old Feb 2, 2013 | 02:50 PM
And clutch bracket is not broken.
Old Feb 2, 2013 | 03:05 PM
HighLux's Avatar
They didnt steal em. They did it with bad intentions.
You got people pissed at you?
Old Feb 2, 2013 | 03:12 PM
I don't think I have lately, And I there is multiple people with yota's at my school, So who knows.
Old Feb 2, 2013 | 03:55 PM
Im confused, any help?
Old Feb 2, 2013 | 05:47 PM
RogueYota's Avatar
Check the pedal adjustment.....mine always backs out and I think my clutch is slowly going out. Does the pedal seem floppy?
Old Feb 2, 2013 | 06:18 PM
Thanks for the feedback! and ill check it in the morning, but i can tell the clutch is not hard at all to press dont while bleeding, but afterwards its hard so I think its good. but ill make sure to check it in the morning. I appreciate it guys!
Old Feb 3, 2013 | 01:33 PM
Clutch Pedal is fine, please help! im stuck
Old Feb 3, 2013 | 01:40 PM
When bleedign the clutch do you press the slave cylinder in before tightening the bleeder valve?
Old Feb 3, 2013 | 01:48 PM
HighLux's Avatar
Have someone in truck....they will pump pedal 5-6 times then hold pedal in.
You crack bleeder for a sec till fluid comes out. Repeat several times.
Kep eye on clutch master cylinder fluid level. Fill as needed.
Old Feb 3, 2013 | 02:49 PM
Now its like my clutch is stuck in, it wont even go when i start in gear, what the frick, any suggestions? btw, happy game day!
Old Feb 3, 2013 | 06:32 PM
timothy47129's Avatar
Did you pull the pressure plate and inspect the clutch disk before you bolted it back in? i would have to guess when the trans separated from the engine the input shaft was no longer being supported by the pilot bearing and caused the clutch disk to get damaged by warping it or messed up the teeth the input shaft slide into and now it's binding up.
Old Feb 3, 2013 | 06:58 PM
Bigblock's Avatar
Bingo !
Old Feb 4, 2013 | 12:05 AM
wyoming9's Avatar
Red face
I am guessing you never pulled it apart to check things .
it is possible the clutch release bearing holder popped off of the clips or came loose so it does nothing when you push the pedal.
Someone did a lot of work to get those two top bolts loose .
I have never been able to get them without pulling the crossmember and rear drive shaft.
Old Feb 4, 2013 | 02:54 AM
rustytaco's Avatar
Sounds like you need to pull it and inspect it for damages could be the clutch fork came off the pivot bolt or the bearing
Old Feb 4, 2013 | 06:15 AM
Im not very smart when it comes to working on trucks, yet im learning. I started pulling it last night, and got dark and started snowing, so ill finish after school and ill take some pictures.
Old Feb 4, 2013 | 06:17 AM
By getting some extenders its not hard at all.
Old Feb 4, 2013 | 08:29 AM
a few extentions and a swivel in the middle of the 2 makes it easy
