I ate my steering alive
Old Aug 19, 2012 | 03:42 PM
theoi's Avatar
I went up in the hills and jacked my steering up.. the pitman arm rod end was all sloppy so I decided to replace the pitman arm, all the rod ends and the adjusters.. but when I tried to put them in the inner rod ends are hitting the frame..
I'm 99% sure the pitman arm is aligned right and everything else is installed correctly.. I think the shaft coming out of the steering box is bent, is that even possible? that shaft is beefy
Old Aug 19, 2012 | 05:07 PM
waskillywabbit's Avatar
Doubt it's bent.
Marks on shaft and pitman arm on bottom to align.
:wabbit2:
Old Aug 19, 2012 | 06:08 PM
oldblue's Avatar
i would think if that shaft bent the seal would leak. sure you didn't put it on upside down?
Old Aug 19, 2012 | 08:18 PM
theoi's Avatar
Thanks guys can anyone think of any other reason why they would hit?
Old Aug 19, 2012 | 08:38 PM
vital22re's Avatar
totally a bro
Most likely the steering relay rod is bent. Check with dealer if the steering relay rod has been replaced under the recall.
Old Aug 20, 2012 | 08:44 PM
theoi's Avatar
Thanks vital it was totally the relay link got one from a wrecking yard and I'm up and running
I didn't even know about the recall but I called with the vin from the truck I pulled the relay rod from and it had been replaced..
Thanks again
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
