How do you remove the Power steering pulley?
Old Jul 1, 2007 | 04:50 PM
pyromjm's Avatar
following the steps to change my water pump and timing belt, fsm says remove the ps belt and pulley, how do you do that the pully just turns when i try to remove the bolt.
-mike
Old Jul 1, 2007 | 05:46 PM
pyromjm's Avatar
-mike
Old Jul 1, 2007 | 05:49 PM
Bigblock's Avatar
Leave it on there,you can do all that without removing the pulley.
Old Jul 1, 2007 | 05:54 PM
navyredneck's Avatar
I'm assuming you mean the crankshaft pulley...
In that case you need to put your truck in gear (high I think). I used a 2 foot breaker bar. Some on here talk about using the starter to loosen the crankshaft bolt. I had to use 6 minutes of heat using a torch to get mine to loosen as the motor was already out of the vehicle.
Old Jul 1, 2007 | 06:02 PM
pyromjm's Avatar
no i mean the power steering pump pulley..
Old Jul 1, 2007 | 06:04 PM
superjoe83's Avatar
to remove the PS pulley leave the belt on to loosen the nut, then remove the belt and nut and the pulley should just pull right off
Old Jul 1, 2007 | 06:13 PM
waskillywabbit's Avatar
X2 It has a notched keyway to keep it from spinning but it is just pressed on there.
Old Jul 1, 2007 | 06:34 PM
pyromjm's Avatar
hm... thats what i tried first but the belt is slipping...
-mike
Old Jul 1, 2007 | 06:35 PM
82yota's Avatar
You're doing exactly what I did last week on exactly the same truck. I've got a 92 xtra cab v6 5 speed. What I did was wrap a piece of rope around it with a slip not type of thing to hold it there and let friction do what it does best. But like the other guy said I don't think you really have to take it off. I don't know why it said you have to because all you do is lay the pump down near the frame anyways.
Old Jul 1, 2007 | 06:36 PM
DeathCougar's Avatar
sometimes they corode on there. Put the nut back on, get a soft faced hammer, and tap on the nut while pulling on the pulley. It will back off slowly.
Old Jul 1, 2007 | 06:37 PM
superjoe83's Avatar
-mike
you may have to push down on the belt while trying to loosen for it to grab enough
Old Jul 1, 2007 | 06:47 PM
pyromjm's Avatar
ok, i will try your suggestions, thanks ill let you know how it goes.
82 Yota, any tips from your experience last week? Did you do it with or without the 'special' tools?
Old Jul 1, 2007 | 06:50 PM
95RunnerSR5's Avatar
mine was stuck on, had to use a spanner fork and BFH to remove it
Old Jul 1, 2007 | 06:52 PM
pyromjm's Avatar
what is a spanner fork and a bfh
Old Jul 1, 2007 | 07:01 PM
for pics
A spanner fork is a spanner fork and a bfh is a big forking hammer.
82yota's Avatar
Well to get the nut loose I used the rope and a wrench and to get the pulley off I threaded the nut back on so it was flush and put a prybar behind it pryed on it and hit the bolt with the nut on it and it came off. The reason for putting the nut back on is to save the thread. I did a headgasket change on mine and I did it fairly quickly and was my first time working on the thing and there is a pile of wires. I'm slowly getting the thing tuned and running right. And when putting things back together stay with the manual because it will tell you to put things back in a specific order and it is right. I had to take things apart a few times cause I skipped a few steps every now and again. Oh and one more thing, antiseize compound is your friend when putting it back together.
Old Jul 1, 2007 | 08:32 PM
Blurr's Avatar
backed. leave the pulley on and remove the PS pump from the bracket and shift it out of the way.
Old Jul 1, 2007 | 08:53 PM
pyromjm's Avatar
dont know what id do without you guys. ive been a yota owner for about a year, and this is the first project ive done on it.
keithporter83
Jul 24, 2015 07:37 AM
luckypig44
Jul 19, 2015 11:25 AM
dinks07
Jul 15, 2015 05:34 PM
voiddweller
Jul 15, 2015 03:56 PM
jon.r
Jul 11, 2015 03:34 PM
