hot 22re
Old Jul 13, 2006 | 08:30 PM
yotamaster1988's Avatar
hot 22re
:complain: i work at advanced auto parts store and my toyot a pickup 89 22re just started reading hot and the thermostat was just changed could it be my temp sending switch? coolants fin and up but it red
Old Jul 14, 2006 | 12:43 AM
ovrrdrive's Avatar
I really wouldn't count on it being the sending unit...
Did it start right after you changed the Tstat?
In backwards?
Is the water pump circulating good?
If so, I'd change the pressure cap. Believe it or not if these don't hold the correct pressure in the rad the truck will run hot.
If all that checks out, the radiator might be getting clogged up. Consider getting it rodded out or buying a new one.
Old Jul 14, 2006 | 04:15 AM
Intrepid's Avatar
Is it a dual stage thermostat? Is it hot all the time or just for a little while?
Old Jul 14, 2006 | 08:40 AM
newhorizons's Avatar
I had the same probs with my 22re. I went to the carwash and pressure washed all the dirt and grease from under the moter and while i was @ it cleaned/squirted the coils/cooling fins for my radiator/tranny/cooler/air cond fins. made a big diff in how fast the temp went down after a big hill climb. also I make sure the oil is topped off trying to get this little sucker to run cool.although I've seen on this board that the sending units aren't always a good/great indicator of the temp.
the1998sr5
15
Jul 14, 2020 08:35 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
the1998sr5
Jul 16, 2015 06:20 AM
