Hoses
Old Jul 29, 2009 | 03:24 PM
needayota's Avatar
Hoses
hey all,
i am confused on a few hoses that need replacing on the 22re.
what is the name of the right angle 2" coolant hose that is down by the drivers side engine mount that from the timing cover to the pipe and where can i get it?
also i want to replace alot of the hoses on the top of the engine, where can i get those? some of them seem to be prefit. using a straight hose would result in a kink.
thanks
Old Jul 29, 2009 | 03:26 PM
Jay351's Avatar
Most auto parts stores have cut to fit rad hoses for your truck..
Old Jul 29, 2009 | 10:12 PM
the_supernerd's Avatar
The right angle coolant hose is just called a radiator hose. Most auto parts stores will have it, and I believe it is referred to as a "water pump to pipe" hose. Most other coolant hoses are heater hoses.
Can you be a little more specific about the hoses on the top of the engine? Most of the hoses on the top of the engine are vacuum lines, but there are some other types, also. A lot of the pre-fit ones are probably emission lines.
Old Jul 30, 2009 | 03:15 PM
needayota's Avatar
the hose in question on top of the engine is the coolant hose that goes from the t-body to the thermostat.
thanks for the info, i was just concerned about the bend in the hose.
Old Jul 30, 2009 | 08:44 PM
Keith B.'s Avatar
There are 2 of those little ≈5/8" OD coolant hoses in the vicinity of the TB; They're called 'coolant bypass hoses'; They are very specifically molded to fit: I'd order from one of the discount Toyota dealers online. Added advantage of getting Toyota hoses: T. makes really good hoses.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
