Hosed by shop for lock right install, need help figuring out locker issue
Old Oct 27, 2015 | 09:43 AM
Phantez's Avatar
Originally Posted by RJR
This is proper operation. Keep in mind that to unlock the passenger side spinning forward, you have to push the driver's side backward. It's not clear if that's how you've tested it.
I figured that would be assumed. Every direction i tested, i pressed the wheel on the other side the opposite direction than i was trying to spin the wheel i was testing
My guess is that the clearances between the drive plates, or the clearance between the pinion shaft and one or both of the spacers, is not quite correct. When I installed the Aussie in my front diff, the instructions were quite explicit that the clearance between the drive plates when they were pushed against the springs had to be between .145" and .170". Aussie would not warranty the locker if that dimension was out of spec. I assume the LockRite has a similar requirement. (with, of course, likely different numbers.)
I did check this clearance and it was within spec. It was just under the higher end of the acceptable range. I don't remember exact numbers but i think the high end was .170 and i was at like .165 or something like that
There was also a spec for the gap between the pinion shaft and each of the internal spacers (.006" to .020" for the Aussie). Again, the instructions were adamant that that be within spec.
If either of those is out of spec, you may need slightly different thickness thrust washers.
You might call LockRite and ask them.
I didn't recall seeing it ask to check the clearance of the pinion, but that could make sense. I'll have to check the instructions to see if i overlooked it.
EDIT: I checked the installation manual. It has you check the clearance between the two halves of the locker, but not the pinion shaft. This is on page 11 for reference. I don't even know how you'd get in there to check clearance of the pinion shaft. http://www.powertrax.com/0002pdfs/1000708MIF.pdf
Old Oct 27, 2015 | 10:17 AM
RJR's Avatar
RJR
The Aussie had a step where you just had the side gears, spacers, and pinion shaft assembled without the drive plates, so you could get in there. Then you had to pull some things apart again to add the drive plates. Sounds like LockRite has a different process.
I think a call to customer support at Lockrite is the next best option. Aussie was quite helpful, at least for my presales questions.
Edit: I just looked at the manual at the link you posted. The measurement for the pinion to spacer distance is on page 23. It's kind of in the "appendix" section, not in-line in the assembly instructions like you'd think it should be. They give a number of .005 to .020, matched to within .008.
Old Oct 27, 2015 | 10:36 AM
Phantez's Avatar
Dang. I'll call them. I'll be really annoyed if I have to take the entire thing apart again.
Old Oct 27, 2015 | 10:54 AM
RJR's Avatar
RJR
Yeah, that should have been in the step by step instructions, not in the "oh by the way, you should have also done this" section after you think you're done.
Good luck,
Old Oct 27, 2015 | 12:53 PM
  #25
Phantez's Avatar
I called Powertrax. They think it might be a clearance issue with the pinion shaft being uneven as well. I'm really annoyed with this thing. It's super finicky. I'm regretting I bought this instead of a Detroit locker and just replace the whole carrier. I guess I'll see what I find when I take it back apart.
Old Oct 30, 2015 | 07:19 AM
  #26
Phantez's Avatar
I've been looking around but can't find anything. Does anyone know the OEM part number for the thrust washers? Or where I can find them online? This is for an 87. I haven't pulled it apart yet, but if I'm in there I might as well change them out this time. Something must be slightly worn
Old Oct 30, 2015 | 07:34 AM
  #27
RJR's Avatar
RJR
This website should show you what you need. (I'm assuming you have the 22re engine, with the 2-pinion differential, not the 4-pinion V-6 version, based on how you had to disassemble it.)
http://www.toyotapartsoverstock.com/...rimLevel=18292
I don't know if those washers come in different thicknesses. You'll probably have to take your unit apart, measure the critical clearances, and decide what needs to change and by how much. You might be best off heading to your local dealer parts guy with that info.
I'd also suggest measuring the crosspin for tolerance and wear. That's the most likely piece that's out of spec. In fact, for $16, it might be worth just replacing it.
If it's any consolation, I wound up pulling my rear 3rd member 3 times before I got the Detroit True-trac installation working correctly. And that was replacing the whole carrier, so should have been simple. Unless you do this frequently, there are a lot of subtle ways to go wrong.
Old Oct 30, 2015 | 07:40 AM
  #28
Phantez's Avatar
This website should show you what you need. http://www.toyotapartsoverstock.com/...rimLevel=18205 I don't know if those washers come in different thicknesses. You'll probably have to take your unit apart, measure the critical clearances, and decide what needs to change and by how much. You might be best off heading to your local dealer parts guy with that info.
Awesome. Thanks for the reference. The lock right came with a new pinion shaft, so I doubt that's it unless the included pinion is no good. If the thrust washers are different thicknesses, it might be a matter of swapping sides and getting it in an order that works. Unfortunately, since the shop messed it up the first time, I'm not sure if the thrust washers were on the same side they originally came from or not. I'll post up what I find with a feeler gauge
Old Oct 30, 2015 | 07:44 AM
  #29
RJR's Avatar
RJR
Just note I gave you the parts diagram link for a 1993 V6. I went back and looked at your original post and saw it was a 1987, so I've edited that link to get you in the right place.
Old Nov 10, 2015 | 08:47 AM
  #30
Phantez's Avatar
Just an update, i haven't taken the rear end back apart yet because my daily driver superduty has been loaded up with sand and rock, so i've been carefully driving around the toyota. The other day, the locker started releasing. I've come to realize its always released on right turns and is almost completely silent when it ratchets. Left turns are now releasing too, but it's super loud. People stare lol. I expected it to be loud, but it seems a bit excessive. I wonder why it's just now starting to release and why it's so much louder than it is on right turns.
jashoeuh
Nov 18, 2024 08:08 AM
westonian18
May 1, 2020 06:38 AM
polo451
13
Nov 20, 2016 07:49 PM
nonstop
7
Aug 11, 2015 09:26 AM
cgilley
Jul 25, 2015 10:55 PM
