hood coming unglued from inner hood frame
Old Jan 28, 2024 | 03:18 PM
mckidyll's Avatar
Surely I'm not the only one with this problem. Looking at the underneath side of the hood on my 88 pickup, seems the hood bracing struts have become unglued from the hood itself. Some kind of heavy duty adhesive was used to hold them together, and has failed. Images attached. So WHAT substance is used for that purpose? Anyone have first-hand experience gluing it back together? Would appreciate advice! Thanks.
Old Jan 28, 2024 | 05:29 PM
jjswenn's Avatar
5 Year Member
Hood frame to panel
Yes, this is common in these older Toyota trucks. On my 95 pickup I used Permatex “the right stuff” to glue the frame and hood panel back together, and added some extra in there to keep it solid. My hood was starting to squeak and make annoying noises at times. Now, any RTV type material would work.
Old Jan 29, 2024 | 07:21 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Yep, I reglued mine.
I took the hood off and laid it flat, and then glued. you'll notice the difference the first time you close the hood.
Old Jan 31, 2024 | 12:15 PM
Melrose 4r's Avatar
5 Year Member
I used the special 3M two part stuff which is comparable to the original. The autobody supply store loaned me the gun that dispenses it. By “special” I mean expensive.
Old Jan 31, 2024 | 12:52 PM
mckidyll's Avatar
Melrose, do you remember the NAME of that 3M two-part stuff? Actually I just ordered some of the Right Stuff, but I'm curious anyway.
Old Jan 31, 2024 | 06:52 PM
Melrose 4r's Avatar
5 Year Member
Pretty sure it’s 3M 08115 panel bonding adhesive.
nickr9287
Jan 23, 2007 08:27 PM
FUZION
Jun 14, 2005 01:21 PM
alltrac165
Oct 22, 2004 10:39 AM
Erc
Dec 23, 2002 09:29 PM
NerfHerder-97SR5-
Aug 18, 2002 12:56 PM
