High A/T oil temp
Old Feb 21, 2007 | 06:36 PM
rezrunner92's Avatar
Originally Posted by Dublin
I can't agree on the "dumb" comment, mainly because OD is for sustained highway speeds and on this stretch of road unfortunatly your lucky to have an average speed of 50. The speed limit is 65 but I don't believe OD was designed to assist the tranny jumping from 45 to 65 and back over a distance that small. I would think it would be as bad as leaving it in OD in town. Correct me if I'm wrong, I don't think i'm dumb but it's possible i'm uninformed.
I don't think you are dumb either. You are most definitely however uninformed.
Slippage equals friction equals heat.
Lower gear, more torque, more torque converter slippage heat rises faster.
Higher gear at cruising speed, less torque, less torque converter slippage but still slippage so there is heat.
Torque converter locked up, little to no slippage, little to no heat generated.
*edit* The number one enemy of automatic transmissions is heat.
Old Feb 21, 2007 | 06:43 PM
slosurfer's Avatar
I don't know about a break in period, my concern is that the reason for OD is an additional gear for "maintained" highway speed. Should I use OD at an inconsistant highway speed, wouldn't it be like not down/up shifting with a standard, wouldn't your fuel savings be tossed anyway?
I don't know about the fuel savings, but you aren't losing any fuel savings compared to running with OD off. Like mentioned before, heat is the #1 killer of automatics, you would be amazed how fast the temp cools when OD kicks in. I too, have the 33's with 4.88's so I feel your pain. My OD is constantly kicking on and off, but I can tell you that I appreciate everytime it kicks on and I see my tranny temp take a dive.
Old Feb 21, 2007 | 06:49 PM
Dublin's Avatar
Thank You rezrunner92 & slosurfer,
This makes it much clearer. Correct me if i'm wrong. Hwy speed vairiable or constant & unlocked TC higher = higher friction & temps. the same with locked TC = lower Friction & temp. Now, what if any effect with 45mph to 65mph and back over & over a short distance on acceleration. I'm thinking longer transmission life and reduced gas mileage. The reason I ask is this is almost a daily route for me.
Old Feb 21, 2007 | 06:50 PM
yota_krazy's Avatar
rezrunner hit it on the nose. There is no reason not to have overdrive on when highway driving, its just wasting fuel and building heat to not have it on. Just poke the button and your problems will probably disappear. Did they cut and clean your old torque converter when the trans was rebuilt?
Old Feb 21, 2007 | 06:56 PM
  #25
The time you want to have overdrive cancelled is if say you are pulling a trailer. You don't want to use overdrive in a towing situation except when you are cruising and not pulling big hills.
  #26
Dublin's Avatar
New torque converter, that one was a freebee, Seems it got knocked off the bench and they didn't want to chance it. Unlucky them, Lucky me.
Old Feb 21, 2007 | 07:00 PM
  #27
Dublin's Avatar
Still OD off in the city right? Or is there no way that the TC can lock at lower speeds if OD was left on.
  #28
Lucky you indeed, last week I accidentally gave the TC guy one I was supposed to keep as a core. That customer got a new one on me. he didn't need it but hey, new parts is new parts right?
BTW I don't really tell my customers to take it easy when I do an overhaul on a tranny. I tell them to drive it like you stole it, because I know they are probably going to give it heck the next week anyway to make sure I did a good job. Good thing I do.
Old Feb 21, 2007 | 07:01 PM
  #29
yota_krazy's Avatar
you dont need to have the OD on in the city, I would just use it for highway/cruising speeds.
Old Feb 21, 2007 | 07:02 PM
  #30
I think that the tc will apply as long as the switch is not cancelled. IIRC the cancel button prevents lock up. I may be wrong about that one.
Old Feb 21, 2007 | 07:03 PM
  #31
slosurfer's Avatar
I don't think you will have reduced gas mileage, your acceleration from 45-65 is going to be the same as with OD off, because with your gears and tires it won't hold OD for that acceleration. What it will do is once you get to speed OD will kick in and will help your tranny temps at least till the next time it kicks out of OD. I feel for you, I don't like driving mine for short trips on the highway. Mine isn't a DD anymore, otherwise I would have kept my set of 31's that I just sold. I can't wait to regear. I have a 5.29 geared front diff ready to put in, but now I have to find one for the rear.
Old Feb 21, 2007 | 07:05 PM
  #32
slosurfer's Avatar
I have not noticed any difference between OD on or off in the city.
  #33
ChickenLover's Avatar
Still OD off in the city right?.
I leave my OD on all the time. The only time you need to turn OD off is during long/steep highway inclines and when towing.
Old Feb 21, 2007 | 07:07 PM
  #34
95RunnerSR5's Avatar
x2, even though you are shifting into and out of OD in the city, the time spend in OD is helping to cool your tranny. I leave it on all the time except for when towing and have never had a problem.
Old Feb 21, 2007 | 07:13 PM
  #35
Dublin's Avatar
Thanks Guys, You are a great help. The slushboxes have always been an unknown area for me, I grew up with Detroit 70's Muscle spinning syncro's & gears. But when it comes to something that bleeds red it's like "Yikes" that goes for my rig or me.
Old Feb 24, 2007 | 08:52 AM
  #36
Dublin's Avatar
Ok back to revisit this problem, As it turns out I was driving with OD "on". I thought it was like the work truck button in OD on, but on the Yota I pushed the button in and the lite says "OD off". So now what would the problem be, I had been driving the old tranny with over 238,000 for 5 years no problems with the exception a few years ago high temp came on after a 200 mile drive, then went out never to rear it's ugly head again.
Old Feb 24, 2007 | 08:57 AM
  #37
Your torque converter clutch or some other friction element within the unit could be starting to fail. When they start to fail they will slip a little before applying completely. If this is the case you will be looking at a tranny overhaul shortly. Could also be the cooler is restricted. but there wouldn't be any reason for the cooler to be restricted unless the unit is giving off fiber or metal. I would say first off add an external cooler.
Old Feb 24, 2007 | 09:06 AM
  #38
Dublin's Avatar
Wouldn't they have replaced these parts? I know the TC is new, but I would think you could get a bit more than 200 miles on a rebuild. At this rate I'll need to stock up on at least 50 or more rebuilts to make it through the year. I'll check with the shop and get the specifics on what was and wasn't.
Old Feb 24, 2007 | 09:11 AM
  #39
slosurfer's Avatar
What was the reason for getting the rebuilt tranny in the first place?
Old Feb 24, 2007 | 09:19 AM
  #40
Dublin's Avatar
Tranny was slipping badly in all gears.
