Hey coilovers guys. Got a ?
I've got a 92 standard cab short bed 4x4. I'm putting a 4link in the rear with 14" coilovers (dual rate) and was wondering what approx spring rate might work well. Any help is appreciated. Also I'm set up for a slight /\ for shock angle. About a total of 8" wider mount on axle than hoop mount up top. I do carry a spare in bed and small tool box also if that factors in. I'm going for a low ride height as I am running long travel ifs up front and don't focus on rock crawling. Hope this is enough info.
Bought the coilovers today and went with 200# over 300# springs. Run-in will be driving to K.O.H. and then I'll have Fox adjust valving on the lakebed to see how close we can dial it in. I'll put up numbers as I go to help others with choosing their setup.
