HELP! Rear Wiper Wont stop wiping!!
Old Nov 28, 2009 | 02:36 PM
mierzwa49's Avatar
Exclamation HELP! Rear Wiper Wont stop wiping!!
I have a 93 toyota 4runner, and when i pressed the rear wiper button the wiper doesnt stop. i have to disconnect the wiper motor but when i do this my rear window wont go down to enable me to open my trunk! What do i need? a new switch or a new wiper motor or is there some sort of fuse? please help!
Old Nov 29, 2009 | 09:46 AM
bugs1961's Avatar
Sounds like a bad switch. Disconnect the switch and test for continuity with the switch on and no continuity with the switch off.
Old Nov 29, 2009 | 09:51 AM
cgeorge's Avatar
man.. I could have used your wiper earlier today.. too much chili and beer last night!!!!! (j/k)
I bet it is the switch..
Old Nov 29, 2009 | 11:19 AM
mierzwa49's Avatar
re
I took the switch completely out , like disconnected it but the wiper still keeps wiping. should i get a new switch?
Old Nov 29, 2009 | 11:51 AM
myyota's Avatar
If you have the switch removed and the wiper is still on, then its not the switch. Locate the relay box that controls the rear window and wiper and unplug it and see if the wiper stops then, if it does then its possible one of the relays has gone bad and is stuck on (this is only a guess on my part), you can get new relays to rebuild the relay board, ive done this before, because to replace the complete relay box is 300-400 dollars, but you can get the relays needed for less than 20.00 dollars.
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
msane99
Jul 17, 2015 10:13 AM
icentropy
Jul 11, 2015 07:21 AM
