Help! Not running on all cylinders.
Old Feb 17, 2016 | 05:02 AM
FinallyOffRoad's Avatar
I'm definitely not running on cylinders five and six. I pulled 1, 3, 5, and 6 spark plug wires, (I stopped after pulling two dead cylinders). I'm getting power from the distributor, as its clicking when I unplug the wires which are new, and I replaced the spark plugs just a couple weeks ago. What could be the problem? Clogged injectors? Every time I start it up from cold, it takes a good 5 or 6 tries for it to finally turn over.
Old Feb 17, 2016 | 03:06 PM
92ehatch's Avatar
Your post is hard to understand.
However. Basic things to check.
Spark. Pull the wire and put a spark plug on it. Ground the plug by touching it to the chassis. Turn engine and see if it sparks.
Bright white or blue. Yellow or orange is no good
If spark is good you need to see if you're getting fuel. My favorite quick way to do this is pull the spark plugs and place a towel over the holes and see if they get fuel on them while cranking. I would also disconnect the igniter so it doesn't spark and start a fire
If those check ok then a compression test is next.
btu44
Oct 7, 2016 08:03 AM
sechott
Dec 29, 2015 05:06 AM
Mason King
Dec 16, 2015 12:29 AM
dr1553
Dec 10, 2015 01:53 PM
PureTacoma_Tundra
PureTacoma_Tundra
Dec 8, 2015 09:20 AM
