Help. No 5th or Reverse.
Old Jun 5, 2016 | 11:01 AM
Chick-N-Picker's Avatar
1989 Toyota 3.0 4wd 5 speed.
I recently lost reverse in my truck but was still able to get in 5th but it was difficult. Now I have no 5th as well. Also I have a lot of play and the shifter can go all the way over the 4wd shifter. However 1-4 is perfectly fine except for a little play in shifter.
I believe based on research that it is the shifter seat and socket (bushing).
Does this sound correct?
Also I've worked on vehicles a lot but not a 5 speed yet. Truck is fairly new to me. I was thinking of getting a marlin crawler shifter seat and heavy duty socket (bushing).
Are these good or dhould i just go the NAPA way. Do I only need one bushing or should I get one for every gear? Sorry new to working on straight drives.
Old Jun 5, 2016 | 01:56 PM
Flash319's Avatar
The bushing is just for the seat where the shifter pivots in. Just pull the shifter assebly apart in the trck and have a look. Sounds like you have bigger problems then just shifter seat bushing. Shift fork broken.....
arlindsay1992
Nov 16, 2016 03:45 PM
steele34
Apr 10, 2016 11:42 AM
ZRTALPHA1
Feb 21, 2016 12:12 PM
