help, gear stuck!
Old Jan 10, 2010 | 03:01 AM
peapicker's Avatar
If your transmission was ok when you parked it, I would not worry about it. should be fine.
Old Jan 10, 2010 | 10:18 AM
rangerruck's Avatar
it doesn't matter if you just parked it before, and suddenly it is not working.
His probs are EXACTLY, what I have just encountered. the above dude is right; if you can shift when it is off, but as soon as you turn the key on, you cannot shift, you have a problem with your clutch kit; one or more of the parts-pressureplate, rotor, throw out bearing. Also secondary possibilities are the clutch cyl, slave clutch cyl, bracket plate is cracked on the floorboard, or the slave clutch forkpiece.
next prob is the tranny itself, synchros or other parts, which is just do a tranny rebuild and get it over with.
Thirdly, it could be both, you are in need of a new clutch kit assy., and a tranny rebuild!!!! This is what i needed, total cost was about 1500 bucks, parts and labor. Not including towing, or fluid drains/refills, or putting on the slave cyl,
that I tried to put on myself.
westonian18
May 1, 2020 06:38 AM
polo451
13
Nov 20, 2016 07:49 PM
fountain
Dec 31, 2015 06:08 AM
pyramid
Jul 30, 2015 10:05 AM
Poncho0206
Jul 10, 2015 06:21 PM
