Help Changed cold start injector no run anymore 3.0
Old Apr 4, 2009 | 12:16 PM
olharleyman's Avatar
OK so I changed my cold start injector and started up the and it stalled started it again and ran fine.
Then I was trying to find my miss and started unplugging spark plugs pulled #2 and it died now when I start it it only runs for about 2 secs and dies and will not run any ideas?
Just to make sure it was not csi related I replace the stock csi and still no go
Old Apr 4, 2009 | 01:01 PM
Marc's Avatar
That running for 2 seconds sure sounds like the VAF is not connected.
Could the wire have come unplugged? Or, if the intake hose for the VAF had a leak, that would cause the same symptom.
Good luck.
Old Apr 23, 2009 | 07:34 PM
guntee1's Avatar
what is the vaf and where is located
Old Apr 23, 2009 | 07:50 PM
24Runna's Avatar
it is on the top of the air filter housing.
Old Apr 24, 2009 | 05:29 AM
Marc's Avatar
harleyman, did you get this thing running?
Old Apr 24, 2009 | 06:33 AM
thook's Avatar
It's the vane airflow meter......on top of the air filter.
Team420
Jan 12, 2021 04:57 PM
Alaskan91
Sep 21, 2015 04:39 AM
Sandman
Jul 23, 2015 08:15 PM
jmc88runner
Jun 18, 2015 03:39 PM
