help
Old Aug 27, 2016 | 12:31 PM
Larry H's Avatar
help
Can anyone help have a 1993 Toyota 22re check engine light comes on and off jumped Te1 and E1 at diagnostic box check engine light keeps on blinking got scanner it says no communication have checked fuse does 0ne of 2 pins have voltage and is 1 a ground if so which is it
Old Aug 27, 2016 | 12:51 PM
scope103's Avatar
Sorry, I can't tell what you are saying. Use some periods, or commas. Try to write like you want someone to understand it.
When you jumper TE1 to E1 it is SUPPOSED to blink the check engine light. It either blinks evenly at about 2 hertz (no codes), or it blinks in groups, giving a 2 digit code.
http://web.archive.org/web/201410310...26diagnosi.pdf
Old Aug 27, 2016 | 12:59 PM
Charchee's Avatar
QUOTE
"Sorry, I can't tell what you are saying. Use some periods, or commas. Try to write like you want someone to understand it."
Absolutely!
With the fuse in, attach the clamp of your test light or black multimeter lead to a good ground and probe both sides of the fuse. If it's good, you will see voltage on both sides. If you get voltage on one side and not the other, the fuse is bad.
1980 Pinellas
Jan 11, 2019 11:25 AM
Luther
Aug 6, 2016 03:11 PM
TroyBCCS
Aug 4, 2016 09:54 AM
128keaton
Jul 31, 2016 11:32 AM
