help!!!
Old Aug 9, 2013 | 05:03 PM
87DD's Avatar
help!!!
I Have An 87 4Runner With The22Re 5 Speed, It Runs Fine In Neutral And Reverse But As Soon As I Let The Clutch Out In Any Forward Gear It Starts To Miss And Run Like Crap. Im Stumped So Please Help Thanks.
Old Aug 9, 2013 | 11:15 PM
wyoming9's Avatar
Red face
Just when did this start??
So your saying you can drive around all day in reverse it works fine .
Sounds to me like perhaps your rear brakes are seized .
More then likely where the bell cranks are attached to the brackets
Old Aug 10, 2013 | 07:39 AM
Stetson_md's Avatar
If you put it in 4low can you move foward Without probs? When my carb was way out of aadjustment and fuel pump was messed up I could only move around.in reverse and low range without it spitin ansld sputterin and ultimately dieing
Old Aug 10, 2013 | 07:59 AM
87DD's Avatar
yes It Will Do 40 In Reverse All Day But The Second I Put Start To Let TheClutch Out It Acts up
Old Aug 11, 2013 | 08:28 AM
87DD's Avatar
nobody Has Any Other Ideas?
