help!!!
help!!!
I Have An 87 4Runner With The22Re 5 Speed, It Runs Fine In Neutral And Reverse But As Soon As I Let The Clutch Out In Any Forward Gear It Starts To Miss And Run Like Crap. Im Stumped So Please Help Thanks.
Just when did this start??
So your saying you can drive around all day in reverse it works fine .
Sounds to me like perhaps your rear brakes are seized .
More then likely where the bell cranks are attached to the brackets
If you put it in 4low can you move foward Without probs? When my carb was way out of aadjustment and fuel pump was messed up I could only move around.in reverse and low range without it spitin ansld sputterin and ultimately dieing
