help with 1995 4runner differential
Old Mar 10, 2011 | 02:17 PM
DeathCougar's Avatar
Originally Posted by RE-RE
You have 4.56s. No such thing as 4.55.
There is in a T100
Old Mar 10, 2011 | 02:18 PM
spitfire4's Avatar
close enough. isnt it really a 4.556?
Old Mar 10, 2011 | 04:10 PM
Yea, something like that
Old Mar 10, 2011 | 04:45 PM
kiyobrown's Avatar
I am currently running a set of 4.56's.
Old Mar 10, 2011 | 05:39 PM
  #25
Sportsmanphil's Avatar
The short shaft fits through the diff housing and into the carrier. The short shaft is supported through the carrier bearing on the short shaft side.
If that carrier bearing was bad, your problems would be much greater than a loose shaft. Im wondering if the short shaft has worn. Once play starts it will accelerate wear to the shaft.
Post some pics if you can.
Old Mar 10, 2011 | 08:40 PM
  #26
spitfire4's Avatar
I dont think so... at least on mine the needle bearings in the middle of the crown/pinion is what the short shaft rides on. the carrier bearing isnt a double bearing with 3 sides and 2 sets of BBs. Im not a yota expert but I do work on cars full time. my short shaft is fine; splines look good even at the end where the clip is; I also mic'ed the shaft and saw about .001 difference where the needle bearings run... so the needles bearings are bad along with the side gears.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
AaronM
Jul 8, 2015 07:15 PM
