help with 1986 pickup
Old Jul 8, 2015 | 01:24 PM
raiderhawks00's Avatar
So I've got a 1986 pickup, it's a sr5 with the 22rec motor. I started the truck up just fine like 3 days ago and now when I go to start it, it won't start it cranks but won't turn over and sometimes when I'm trying to start it and I look under the hood there is a little bit of white smoke coming from the area of the throttle body and there is a faint smell of gasoline. Any help/suggestions would be greatly appreciated
Thanks
Old Jul 8, 2015 | 04:17 PM
wyoming9's Avatar
Red face
Was working good then just started the not starting problem??
Does it start after cranking a few times Then how does it run??
When was your last tune up??
What have you done troubleshooting so far??
Old Jul 8, 2015 | 06:23 PM
Huntingtruckcletus's Avatar
I would check the cold start intake valve.. Mines stripped a bit an it leaks air a tad bit but not gas.. When I could out an crank it for the first time in a while I have to left it crank over 5-10 seconds a couple times before it starts.. It's easy to fix but I haven't found one for under $150 so I'm just gonna let it ride.. Yours could just be a little lose
nanhodges2733
May 29, 2020 03:28 PM
mskalmus
May 28, 2017 07:51 AM
garagespace
Jul 9, 2015 08:37 AM
karbin
Jul 5, 2015 11:37 PM
