YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   help with 1986 pickup (https://www.yotatech.com/forums/f116/help-1986-pickup-289797/)
raiderhawks00 07-08-2015 01:24 PM
So I've got a 1986 pickup, it's a sr5 with the 22rec motor. I started the truck up just fine like 3 days ago and now when I go to start it, it won't start it cranks but won't turn over and sometimes when I'm trying to start it and I look under the hood there is a little bit of white smoke coming from the area of the throttle body and there is a faint smell of gasoline. Any help/suggestions would be greatly appreciated
Thanks
wyoming9 07-08-2015 04:17 PM
Was working good then just started the not starting problem??
Does it start after cranking a few times Then how does it run??
When was your last tune up??
What have you done troubleshooting so far??:wrench:
Huntingtruckcletus 07-08-2015 06:23 PM
I would check the cold start intake valve.. Mines stripped a bit an it leaks air a tad bit but not gas.. When I could out an crank it for the first time in a while I have to left it crank over 5-10 seconds a couple times before it starts.. It's easy to fix but I haven't found one for under $150 so I'm just gonna let it ride.. Yours could just be a little lose
