Head removed but forgot to break pulley bolt
Old Feb 26, 2009 | 03:58 PM
ahickman's Avatar
I tore into an 86 22re last week to do a HG replacement. Ended up deciding to pull the water and oil pump, but forgot to break the pulley bolt free before dissasembling the intake plenum and peripherals. Got the head back on and the timing chaing set. Thought I could bump the engine a bit to break the bolt using a breaker bar against the rail. Key in, but no starter. I can hear the starter relay, but it does not energize the starter. Threw the fuel rail, MAF and plenum on. Connected everything but the distributor. No starter. What else does the ECU look at before allowing the starter to bump?
Old Feb 26, 2009 | 04:47 PM
hodgepodge79's Avatar
this won't help with your inop starter, but try the chain method to get your crankshaft bolt off. I love it! https://www.yotatech.com/forums/f116...y-bolt-130240/
Old Feb 26, 2009 | 05:04 PM
RMA's Avatar
RMA
That chain Idea looks good , I use one of these pictured they work great, Yes I have had to file very small nicks on the pully sometimes but its worth it I think.Bought it at napa and I forgot how much.
Old Feb 26, 2009 | 05:13 PM
ahickman's Avatar
Hodgepodge79, thanks for the pointer to the thread. Gave me a couple of ideas.
Old Feb 26, 2009 | 05:41 PM
86tuning's Avatar
It's better to drill 2 holes in a 4' piece of angle iron and bolt it to the back of the engine in place of the flywheel. Zero chance of breaking pulleys and stuff.
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
skoti89
Jul 6, 2015 07:45 PM
