Hard shifting transmission - final solution needed
Old Aug 5, 2008 | 01:44 AM
LittleSilver113's Avatar
Have you tried shifting without the clutch by matching engine speed. Easy way to tell if its clutch or not. Also tell you something about the synchros. If I were you I would just hop on ebay or craigslist you can find a good used transmission for a very good price and a complete rebuilt unit is probably close to a grand with core exchange. If you really like the truck I would plan on that. Either that or find a tranny shop with a damn good warrant Your truck has a v6 so your going to be looking for the r150 transmission/ a 151 will not work if im not mistaken.
Old Aug 7, 2008 | 11:58 AM
AK Ray's Avatar
Holy Cow this is old news.
To update I found that the clutch fluid was basically black water. It looked OK from outside, but once it was drained into a clear container it was totally black and flowed too easily in the jar.
Draining and bleeding off the old stuff took most of an afternoon and restored quite a bit of clutch feeling. However not all the way back to normal. I ordered a new master and slave, but have not yet installed them due to too busy a schedule and some back problems. Just might take it in this fall for valve covers and have the master/slave done at the same time.
Ebay and Alaska don't mix when shipping heavy objects like transmissions. There is one small garage up here that has a stockpile of used parts, but any used part in Alaska needs to be completely rebuilt anyway due to the abuse most trucks see here.
94whiterunner
Sep 22, 2015 07:25 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
jalaber
Jun 10, 2002 06:28 AM
