Getting more horsepower?
Old Jul 5, 2011 | 11:47 PM
  #41
fork's Avatar
Originally Posted by '86Owner
Ok, slightly of topic but not much. I have read that the EB 268 cam is more torquey than the 261, and I have read the otherway around. So which one is more torque and which one is more power/rpm's?
i can't vouch for the 268, but the 261c has been good to me so far on my 22r-e. definitely seems to have more low end grunt than my other 2 22r-e's. it would probably be even better with a carb.
my guesstimated corrections just based on my own experience/butt dyno:
Stock 22r/22re; 96/105hp
Bored over; not sure how much but i think 040 (0.040"), 1-3 hp(guess) does anyone know how much displacement is gained?
Headers; 2-5hp at best and moreso just a difference in curve
2 1/4 exhaust with high flow muffler no cat; 2-5hp +120dB
A/C unit and vacuum hoses removed(except timing and the ones that clean out the valve cover); 0-1hp
Weber 32/36 carb; 10-20hp when tuned right.(Got this from a weber tech)
Timing advanced as far as it'll go running on regular(???? why regular); maybe 1hp or maybe detonation
i wouldnt get your hopes up too high
Old Jul 6, 2011 | 08:54 AM
  #42
'86Owner's Avatar
Thanks for the feedback on the cam. And I think your right on the displacement hp numbers. I figured out what displacement you gain, and with 040 over its 55cc. So it would be like having a 55cc engine along side your 22r. And removing the A/C and vacuum hoses is not so much adding horse as it is taking away drag so more gets to the tires, so I dunno. I think your right on the carb too, though maybe slightly more like 15-25, It makes my pickup get up and go pretty good and I haven't regeared. And regular is cheaper, lol. And tecnically you should be able to get more timing advance with a higher octane fuel without detonation.
Old Jul 6, 2011 | 08:56 AM
  #43
'86Owner's Avatar
Oh, fork, how is the power band on that cam? Like what rpm's do you have the best power/torque?
Old Jul 6, 2011 | 10:08 PM
  #44
fork's Avatar
i have no dyno to go off of, but just to compare it to my other similar spec'd 22r-e's i would say it starts making a difference to me around 1500rpm(or lower) up through the usable range. i would definitely recommend it in any situation compared to the stock cam. its considerably rougher at idle than the stock cam on my efi though. i dont care one bit. the next time around ill try a 268 just to see if theres much of a difference. itll still be apples to oranges though since the comparisons arent at all scientific. in any case im satisfied with the 261.
Old Jul 8, 2011 | 11:49 AM
  #45
'86Owner's Avatar
^Hmm, thanks. What is your "usable range"? Like up to 4000?
Old Jul 8, 2011 | 08:20 PM
  #46
fork's Avatar
yea up to 4k, but i shift at about 3 most of the time. i rarely open it up past 3k unless i'm trying to keep up with traffic uphill on the freeway
Old Jul 10, 2011 | 08:15 AM
  #47
'86Owner's Avatar
^Ok, thanks.
Old Jul 11, 2011 | 05:00 PM
  #48
'86Owner's Avatar
Anyone else on the EB 261c?
Old Jul 13, 2011 | 09:04 AM
  #49
hilslamer's Avatar
Originally Posted by The MAN
if you're displacement limited, you can always fix that... with boost
Amen to that!
WhoahTakeItEasy
Engine Swaps
Jun 19, 2015 02:59 AM
KING
132
Sep 4, 2004 09:54 AM
Kenn
9
Aug 15, 2004 12:44 PM
Ry
Jun 18, 2003 08:13 PM
