Which gears
Which gears
I found a website to to help decode your diff and gear codes, but I still cant decode it. can anyone help me, this is what my door jam says:
C/TR 751/CPM
A/TM G144/
A340H
Here is the link:http://www.off-road.com/toyota/tech/other/4_axles.html
Thanks
C/TR 751/CPM
A/TM G144/
A340H
Thanks
Thanks kyle 22r for your help. So are these gears enough to run 33's, and still get ok gas mileage??? I got 31's on 15x10 rims and I get 11-12mpg. No Elton, the spare is under the truck.
What I mean by overgeared is your gears will be a little higher than a stock ratio. It might be a little confusing, but the lower number your gears are, the higher the gears actually are. For example, 5.29s are lower than 4.10s, thus more capable of turning bigger tires. 33" tires, 4.88 gears, and a manual is a good combo. An auto with the same tires and gears would need lower gears to have the same feel as the manual, but is still sufficient. That is why most manual Yotas come stock with 4.10s, while most autos come stock with 4.56s. You having 4.88s with an auto, 33's will be fine. 35's would really be pushing it, and you would find your rig slower.
Originally Posted by Elton
every ones says the 4:88s are perfect for 33s
If you have auto, overdrive will be about worthless with 4.88. 5.29 AT LEAST, and consider 5.71 - seriously, the overdrive on the auto is TALL! I've driven a 4Runner with 3.0, auto, 5.71, 35's and it is a DOG - won't hold the overdrive on anything remotely uphill.
Originally Posted by 881stGenRunner
i have the 3.0, auto tranny in my 88 and i decoded it and it said i have 4.10's, how come it doesn't have 4.56's or 4.88's?
Mike in AR
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
