Gas tank holes
Gas tank holes
My 1988 Toyt Truck 22R 2 Bbl carb has a couple tiny holes in the gas tank.
My first attempt at patching them up didnt work using Auto Parts Gas Tank repair patch kit. Now I tried again and waiting for it to dry a day later to see if it will work.
If it still leaks is there a way to weld or patch weld a Gas tank to stop my leaks? The 3 tiny holes are in one part of the tank and the patch I am trying covers about 3 square inches.
You can use bar soap as a temporary patch. Just take a bar and rub it hard against the holes and it will plug them for a while.
There are various patch systems available, but I have never had very good luck with them.
Welding on a used gas tank is a job that is best left to professionals. The tank must be dropped, purged, filled with something inert and then and only then can it be safely welded on.
Originally Posted by oaklander
Thanks,
I will take it to a pro but wanted to make sure that is possible to do on an old gas tank.
I assume I can get quotes from body shopes but wasnt sure if patching a gas tank was possible.
My Permetex patch seems to have worked on the 3 small holes.
My last patch lasted about 5 years.
Anyone have any advise or knowledge on how long patches last on gas tanks? My tank has no rust visible from the outside.
I will also put rubber undercoating over the patch area.
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
pyramid
Jul 29, 2015 06:53 AM
