gas pedal still sticks
Old Feb 24, 2007 | 06:03 PM
Toyota D's Avatar
yes i did use the search button and i cleaned out the throttle body with cleaner and a tooth brush. but the pedal still sticks. is there anything else it could be???
Old Feb 24, 2007 | 06:05 PM
Elton's Avatar
peak under the dash and spray the spring and such
Old Feb 24, 2007 | 06:10 PM
Toyota D's Avatar
duh
oh ya duh i dint even think about that! thanks man
Old Feb 26, 2007 | 03:45 PM
Elton's Avatar
so did that help at all ?
Old Feb 26, 2007 | 04:00 PM
saleen9973's Avatar
Check the springs on the TB.
Old Feb 26, 2007 | 04:12 PM
toyota4x4dmination's Avatar
try to lube the throtle cable with wd 40 my 94 toyota pu was acting weird when i let off the pedal i lubed the cable and it works good now
Old Feb 26, 2007 | 04:27 PM
foot0069's Avatar
Cycle shops sell a cable lubing kit that actually hooks around the cable forcing the lube through the outer sleeve. Sometimes works wonders.
Jim
Old Feb 26, 2007 | 04:34 PM
CJM's Avatar
CJM
WD40 isnt lube, hence water displacement 40! Use silicone or actual grease/oil!
smthwsn357
May 1, 2024 07:28 AM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
HollieJayyy
Aug 9, 2015 07:59 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
