gas in oil
Old Aug 22, 2006 | 05:00 AM
bowtiebinder's Avatar
gas in oil
my 92 22re is making oil . it goes up about 1/4 to1/2 inch on dipstick in 500-700 miles. I switched out thefuel pressure regulator on the rail . didn't help. The truck runs great, has only 109000 miles on it. What else to do?
Old Aug 22, 2006 | 05:54 AM
toyaholic's Avatar
that's bad news. it's leaking from the cylinders past the rings. that will kill an engine pretty quick. so your sure it's gas in the oil and not water? does the oil smell like gas. take a little sample and try to light it with a match to see, of course far away from your vehicle.
Old Aug 22, 2006 | 06:00 AM
yes,it smells like gas, but by the rings? this truck has never used oil and always runs good.
Old Aug 22, 2006 | 06:44 AM
eric-the-red's Avatar
Sounds like your engine is running very rich, and the fuel that doesn't get burnt is running down the cylinder walls into the crankcase. That is not good because as the gas runs down the walls it washes away the oil so your rings aren't getting lubricated and will wear quicker.
Old Aug 22, 2006 | 10:52 AM
toyaholic's Avatar
the condition needs to be adressed before it is a problem and you do end up using oil. figure out why you are flooding the cylinders. i wouldn't continue running the truck untill it's fixed.
Old Aug 22, 2006 | 10:56 AM
Injector's? taking it to shop thursday, guess I'll find out then. it just doesn't seem to be running rich. 22-24 mpg with auto trans
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
adammtb
Jul 27, 2015 11:57 AM
Yota.Jay
Jul 23, 2015 08:08 PM
ryerye13
Jul 14, 2015 08:27 AM
