Gas mileage
Old Oct 15, 2007 | 10:36 AM
hard luck's Avatar
Gas mileage
Hello everyone, Just curious to what kind of gas mileage a stock 87 22r turbo auto trans should be getting. Thanks in advance.
Old Oct 15, 2007 | 10:53 AM
RustBucket's Avatar
Tuned up I would guess 20mpg. Assuming you drive it gently.
Old Oct 15, 2007 | 10:59 AM
thook's Avatar
And depends on the tire size....if it's something other than stock. But, yeah, between 17 and 20.
Old Oct 15, 2007 | 11:24 AM
Green Machine's Avatar
I had a 87' 22r-te with the 5 speed and I got between 18 and 21 mpg, with 31's.
Old Oct 15, 2007 | 11:55 AM
Albert.G's Avatar
umm bout 480km a tank, im sure i could have got an even 500, driving so so, all in town
edit, 3.slo
Old Oct 15, 2007 | 05:21 PM
hard luck's Avatar
i have 31's and dont drive it hard at all. its not running to good and gets 14mpg wich sucks. Just put a newly rebuilt engine in it so it has a New fuel pump, fuel filter, plugs, wirs, cap, rotor, and engine. TPS checks out fine.
Can any one give me the part number on the top of the MAF? I am starting to think its not the correct one.
Thanks again
Old Oct 15, 2007 | 05:34 PM
thook's Avatar
Thanks again
31's are a tad large for that rig (the difference being that you have an automatic), but you should still be getting mileage than that.
What makes you think you have the wrong airflow meter? (BTW, you have a Volum Air Flow meter and not a Mass Air Flow meter. I'm not trying to be a prick, but they are different. Same principle, but have different circuitry and work differently. The MAF's are used on later model vehicles. This is just so you know.)
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
