fuel pump 87 pickup whoo,s
Old Jun 24, 2012 | 07:59 AM
my 75 toyota's Avatar
Smile fuel pump 87 pickup whoo,s
Ok so hears the deal finally got my new weber 38 carb installed. Idles good went for a short drive about 2 blocks and it died. Towed home and replaced the fuel filter. Started up ran for about 15 min idling rev it up and notice the filter is a clear one so i see the level drop drastically until i let idle for a min. So it has a stock fuel pump that is mechanical. I was trying to decide between mech or electric. If i got electric i am om a budget so i find a MR Gasket 4 to 7 psi pump and a Mr Gasket regulator. Heres the problem with this setup there is no place to hook up fuel return line to the tank. So can i cap off return line or what. Will a 3 line fuel filter work . Also Weber recomends 3.5 psi since i put bigger mains in it would i need the regulator anyways. Ideals or input anyone thanks
Old Jun 24, 2012 | 10:21 AM
Ok update online research shows the Mr Gasket s12 has a high failure rate so any other suggestions
Old Jun 25, 2012 | 07:30 AM
ratso's Avatar
Put a mechanical pump on it cheap and easy.
Old Jun 25, 2012 | 08:13 AM
will a stock fuel pump supply the weber 38 carb
Old Jun 25, 2012 | 11:27 AM
ratso's Avatar
Yes you only need electronic pumps for fuel injection.
Old Jun 25, 2012 | 03:33 PM
the electronic fuel pump for fuel injection is rated at 38 psi which is way to much for a carb. However i ordered the airtex intank at 5 to 8 psi 50 gph should be fine. will let you know when it comes in
Regency
20
Jan 3, 2020 07:43 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
puffin04
Jul 10, 2015 09:17 PM
87blyota
Jul 1, 2015 05:26 PM
Dennis140
Jun 17, 2015 10:37 AM
