Fuel leak near tank.
Old Oct 23, 2010 | 02:43 AM
  #81
UKrunner's Avatar
Well the right part would have steel fuel line pressed in to it which I aint gonna find at Lowes. This part screws in and seals perfectly. And at some point I'd have to convert the hard line to hose anyway because the fuel filter is connected with hose as the hard line down there has rusted away. All I'd be doing at this point would be replacing about 3ft of rusty hard line with hose.
Old Oct 23, 2010 | 05:03 AM
  #82
irab88's Avatar
i just meant finding the right thread size, not the actual part. your logic is sound, though. if it were me, i would replace all the steel lines with stainless and put proper flares/fittings on
Old Oct 23, 2010 | 05:58 AM
  #83
1990yota-pickup's Avatar
ya cut the broken pipe with a pipe cutter and use high pressure fuel line and clamp it and forget.. you should have no problem with your fuel pressure..
you shouls get the seal stuff you put in the inside of the tank if you dont plan on buying a new tank, and then spray the outside with bedliner stuff...
Old Oct 23, 2010 | 08:52 AM
  #84
UKrunner's Avatar
FARK!!
Anyone have a good tank removal guide?
Old Oct 23, 2010 | 10:40 AM
  #85
808-3VZE's Avatar
Originally Posted by UKrunner
FARK!!
Yup! Dropping a tank is a BITCH!!!
Old Oct 23, 2010 | 12:42 PM
  #86
UKrunner's Avatar
So I'm looking for a replacement and they are all listed as 14 gallons for the '91. I must have a 17 in mine because I've put over 14 gallons in there before. Maybe this is why I cant find a fuel pump bracket and breather that matches mine.
Old Oct 23, 2010 | 02:56 PM
  #87
UKrunner's Avatar
How to you get the electrical connector off the sender? I've lifted the tab but cant pull the connector off the sender.
Old Oct 23, 2010 | 06:01 PM
  #88
some scrap AL and you will be in there just make a bracket
Old Oct 24, 2010 | 08:03 AM
  #89
UKrunner's Avatar
Got tank out, connector undone and also scored a bonus prize - none of the screws holding the pump housing on snapped off.
Old Oct 24, 2010 | 02:17 PM
  #90
well thats good, are you putting tank seal stuff on the inside...
Old Oct 24, 2010 | 05:31 PM
  #91
UKrunner's Avatar
No, the tank is in great shape. There is a rubber coating all over the outside that barely has a mark on it. There is no rusting at all. Inside is nice except for some sediment.
Cant find a diagram or picture that matches this pump bracket though. It has 2 pipes rather than 3 but they face opposite directions. All the drawings I've seen have two pipes that run parallel to each other.
Old Oct 24, 2010 | 07:33 PM
  #92
Challenga's Avatar
What are the two pipes for? On the three pipe bracket one is the out, one is the bypass from the fuel regulator, and the other is the breather that goes to the charcoal can up front. On the 2 pipe bracket is it just an IN and an OUT?
You could tell by where the second pipe outlet is on the bracket. Is the opening at the bottom of the backet or the top?
Old Oct 24, 2010 | 07:40 PM
  #93
Challenga's Avatar
x2 on that advice
Old Oct 25, 2010 | 04:16 AM
  #94
UKrunner's Avatar
The 2 pipe version is just in and out. The breather is on a separate small bracket.
Old Oct 25, 2010 | 08:22 AM
  #95
Challenga's Avatar
Huh...
Old Oct 25, 2010 | 11:35 AM
  #96
UKrunner's Avatar
Old Oct 25, 2010 | 02:29 PM
  #97
Challenga's Avatar
I like the JB Weld.......hahaha
Old Oct 25, 2010 | 02:56 PM
  #98
UKrunner's Avatar
Lasted 1500 miles and only broke because I had a hell of a time getting that fitting loose on the flex hose.
Old Oct 25, 2010 | 05:14 PM
  #99
UKrunner's Avatar
So, part numbers I'm getting for this are:
23206-35290 (10.5xR15 tire) --- Not this one.
23206‑35280
23206-35220
I can not find a picture of either part number.
Old Oct 26, 2010 | 07:50 AM
  #100
UKrunner's Avatar
So any ideas for which part number I need?
