Fuel filter replacement
Old Nov 21, 2013 | 09:26 AM
bspeth's Avatar
Do you guys know the torque specs for the banjo nuts on the fuel filter for a 22RE? Also is a flare wrench required for this procedure or will a regular wrench work?Thanks
Old Nov 21, 2013 | 09:42 AM
scope103's Avatar
What Sayeth the Good Book? http://personal.utulsa.edu/~nathan-b...46services.pdf (22 ft-lbs)
Doesn't the 22re use 2 banjo bolts on the fuel filter? (the 3VZE does not) If so, you'll want to use a socket wrench or box-end wrench. The bolts aren't real hard, so using an open-end wrench risks chewing them up. You don't need flare-nut wrenches on banjo bolts.
Old Nov 21, 2013 | 10:41 AM
bspeth's Avatar
Yes banjos.Thanks for the info.
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
