fuel door hinge help !!! I need your wisdom or ideas
Old Dec 9, 2012 | 03:50 PM
slacker's Avatar
need some help here guys ..
I have built moulds for the fuel doors on a few different year trucks . but the problem now is the hinges . I have tried many "cabinet" type hinges and cant find one that will work .
any ideas ?
Old Dec 9, 2012 | 05:09 PM
yodafan93's Avatar
I got the same problem. Lemme know what you find out.
Old Dec 10, 2012 | 04:35 PM
slacker's Avatar
will do
Old Dec 10, 2012 | 04:59 PM
NickMiller's Avatar
My gas door hinge got FUBAR'd when my brother threw a basketball at it (NO idea why) so I'm looking forward to seeing what you come up with!
Old Dec 11, 2012 | 04:50 PM
slacker's Avatar
I've got nothin' .. I was hopin' someone else has figured something out
Old Dec 11, 2012 | 06:53 PM
yodafan93's Avatar
lol this thread sucks right now, not even a single semi helpful responses.
Old Dec 11, 2012 | 07:36 PM
dakotawho's Avatar
Wish i could help, seen slacker have lots of input other places.
Good Luck and keep up the good work!
Old Dec 11, 2012 | 07:47 PM
yodafan93's Avatar
i have the same issue on my runner. id like to hear a solution. ive heard of using piano hinges but never seen anyone do it.
Old Dec 11, 2012 | 07:52 PM
TrikeKid's Avatar
I don't really see something that isn't similar/same in design to the factory hinge working. To keep the hinge hidden you need the door to come out away from the body at the hinge end as it opens. A piano type hinge is either going to be exposed and make it look like you shop for repair pieces in the cabinet hardware aisle or leave you with poor fit to give you room to make it functional.
Old Dec 11, 2012 | 07:55 PM
snobdds's Avatar
Does Toyota not carry the fuel door anymore; it should come with a new hinge since they are essentially one piece? There design is pretty simple...would you be able to make a couple off of an original?
When I put my fiberglass bed on, I just reused my old fuel door and lined up the hinge holes in the pocket, drilled and used a tiny bolt to hold it together. Seems to be holding up well.
yodafan93's Avatar
which is exactly why i havent bought any piano hinges.
Old Dec 12, 2012 | 04:32 PM
slacker's Avatar
79-83 fuel doors are no longer avaliable .. and the 84-88's are way over priced , and being fazed out .
in any case .. one day .. you will no longer be able to find new or used
Old Dec 12, 2012 | 07:54 PM
yodafan93's Avatar
i have the door, i just need the freaking hinge... lol.
Old Dec 13, 2012 | 03:57 PM
Thelast83inNJ's Avatar
Wander by a newer Ford pickup and check out theirs. Complete unit, door with hinge, all plastic that pops/snaps into sheetmetal then fill neck is screwed to it. I replaced on a I believe 2007? Painted from factory. They have a problem with staying closed so replacement is common. Keep that in mind when designing yours. Now I know you may not see the design when it's in the truck, but maybe you could get a Ford parts person to let you fondle one. That's all I got.
Old Dec 13, 2012 | 04:12 PM
NickMiller's Avatar
Originally Posted by yodafan93
i have the door, i just need the freaking hinge... Lol.
this ^^
Old Dec 17, 2012 | 10:34 AM
Lons81's Avatar
Hey Slacker and others interested. I think what you are looking for is a 1/4" or 3/8" offset concealed blank hinge that has a 1" wide leaf on one side or maybe both sides if you take the lip off the door.
I guess it depends on bulk sales, but I found this link that might help in getting some made. They look similar to the stock ones on one side, maybe they can modify to fit and give you a quote per piece. Hope this may help. http://catalog.monroehinge.com/categ...ncealed-hinges
Old Dec 17, 2012 | 04:58 PM
slacker's Avatar
EXCELLENT post .. thanks , just what I was looking for .. this looks promising
thank you !!
Old Dec 17, 2012 | 05:12 PM
travis_h's Avatar
What year of Toyota do you need the hinge for?
Old Dec 17, 2012 | 09:31 PM
yodafan93's Avatar
i need a hinge for a 1st gen 4runner, which are different from the pickups.
Old Nov 26, 2016 | 09:03 AM
mmacinnis's Avatar
Anyone figure out a way to fix this? My hinge broke off today... would really like to fix it
Thanks
