fuel in crankcase/oil
Old Jan 30, 2013 | 08:52 AM
Marvin Harry's Avatar
1987 toyota 22e starts for a second, floods cylinders with fuel, fills oil with fuel. Replace fuel pressure regulator with a new unit...still the same problem.
Please help...
Marv
Old Jan 30, 2013 | 01:30 PM
Co_94_PU's Avatar
Please help...
Marv
Did you test that regulator before you replaced it?
Have you pulled inspected and tested the injectors?
How about the compression test?
Inspected the fuel return line to the gas tank?
Old Jan 30, 2013 | 02:01 PM
HighLux's Avatar
Injector sticking open
Old Jan 30, 2013 | 04:03 PM
three of the cylinders are flooded with fuel, a lot of fuel. Can a malfunctioning AFM create this problem?
Old Jan 30, 2013 | 04:06 PM
HighLux's Avatar
Check the injectors
Old Jan 30, 2013 | 05:17 PM
BamaYota1's Avatar
Injectors. Check all including cold start.
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
